无法预览
我下载了最新的个人试用 安装文件,安装后,就预览 GettingStarted.cpt,就没反应看到有报错信息如下,该怎么解决呢
2025-05-05 12:27:17
严重:12:27:17 startup-common-4-worker-7 ERROR [standard] ParseError at [row,col]:[1,1]
Message: Premature end of file.
2025-05-05 12:27:21
严重:12:27:21 FineEmbedServerStart-65-worker-1 ERROR [standard] Get latest disk capacity info for temp failed
2025-05-05 12:27:21
严重:12:27:21 FineEmbedServerStart-65-worker-1 ERROR [standard] Get latest disk capacity info for user.dir failed
2025-05-05 12:27:21
严重:12:27:21 FineEmbedServerStart-65-worker-1 ERROR [standard] Get latest disk capacity info for project failed
2025-05-05 12:27:21
严重:12:27:21 FineEmbedServerStart-65-worker-1 ERROR [standard] Get latest disk capacity info for logs failed
2025-05-05 12:27:21
严重:12:27:21 FineEmbedServerStart-65-worker-1 ERROR [standard] get tomcat thread pool info error
FineReport Tq6v5VnJ 发布于 2025-5-5 12:29 (编辑于 2025-5-5 12:31)
发布于2025-5-5 12:31(编辑于 2025-5-5 12:33)
还有检查一下你的C盘,是不是快满了?你是不是管理员?或者右键》以管理员运行设计器看看。
  • 36浏览人数
  • 最后回答于:2025-5-5 12:33
