mac连接远程服务器时保存不成功
mac连接远程服务器时保存不成功
后台报错
javax.crypto.BadPaddingException: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
六月 26, 2025 9:51:55 上午
严重: design_save_report error
com.fr.web.core.A.$E: design_save_report error
        at com.fr.web.core.A.oD.A(Unknown Source)
        at com.fr.web.core.A.B.C.process(Unknown Source)
        at com.fr.stable.fun.impl.NoSessionIDOPService.process(Unknown Source)
        at com.fr.web.core.ReportDispatcher.dealWithOp(Unknown Source)
        at com.fr.web.core.ReportDispatcher.dealWeblet(Unknown Source)
        at com.fr.web.core.ReportDispatcher.dealWithRequest(Unknown Source)
        at com.fr.web.BaseServlet.doGet(Unknown Source)
        at com.fr.web.BaseServlet.doPost(Unknown Source)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:696)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:779)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:227)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
        at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:687)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:360)
        at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:399)
        at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
        at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:893)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1789)
        at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
        at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
        at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
        at java.lang.Thread.run(Thread.java:750)
Caused by: java.lang.NullPointerException
        at com.fr.form.main.Form.readStream(Unknown Source)
        at com.fr.web.core.A.B.F.A(Unknown Source)
        at com.fr.web.core.A.B.F.actionCMD4User(Unknown Source)
        ... 32 more
FineReport aaaaaaa111 发布于 2025-6-26 10:04
发布于2025-6-26 10:05(编辑于 2025-6-26 10:06)
  1. 权限问题:
    • 如果您是非超管用户,您只能在完全有权限的文件夹下新建模板,不能在根目录或不完整权限的文件夹中保存,可能会提示“没有权限!”。远程设计
  2. 模板被锁定:
    • 如果您在保存模板时遇到报错:"xxx.cpt" is locked by user admin with client xxx,这可能是因为该模板被其他用户锁定。此时,您需要等待该用户释放锁定或联系管理员处理。远程设计常见问题
  3. 网络问题:
    • 服务器网络问题可能导致请求失败,例如,某种 SQL 防注入安全策略可能会拦截请求。建议联系网络运维相关负责人,将相关请求加入白名单。
  4. 连接异常:
    • 如果频繁断开连接,可能会导致保存失败。您可以检查网络连通性,确保 VPN 和网络状况良好。
发布于2025-6-26 10:05
这个你服务器不是mac电脑把,jar包不一样,会与问题的
检查线jar包
  • 16浏览人数
  • 最后回答于:2025-6-26 10:06
