逗号替换成顿号并把最后一个顿号改为和
逗号替换成顿号并把最后一个顿号改为和
FineReport yzm215621 发布于 2025-7-14 17:28
共5回答
发布于2025-7-15 08:45
REPLACE(JOINARRAY(MAPARRAY(SPLIT(A2,","),if(index = count(SPLIT(A2,",")) - 1,CONCATENATE(item,"@"),item)),"、"),"@、","和")
ScyalcireLv7高级互助
发布于2025-7-14 17:31(编辑于 2025-7-14 17:35)
公式.rar
参考附件----
  1. 先用REPLACE将所有逗号替换为顿号
  2. 通过REVERSE+FIND反向查找最后一个顿号位置
  3. 计算该位置在正序字符串中的索引
  4. 用REPLACE替换最后一个顿号为"和"
runnerLv7资深互助
发布于2025-7-14 17:32
repalce(字符串, ",","、")
发布于2025-7-14 18:07
if(find(",",A1)>0,
JOINARRAY(REVERSEARRAY(SPLIT(REPLACE(CONCATENATE(LEFT(
JOINARRAY(REVERSEARRAY(SPLIT(A1,"")),""),
FIND(",",JOINARRAY(REVERSEARRAY(SPLIT(A1,"")),""))-1
),"和",RIGHT(
LEN(A1)-FIND(",",JOINARRAY(REVERSEARRAY(SPLIT(A1,"")),""))
,A1)
云波Lv2见习互助
发布于2025-7-15 09:44
IF(  COUNT(SPLIT(A1,",")) <= 1,  A1,  JOINARRAY(    MAPARRAY(      SPLIT(A1,","),      IF(        index = COUNT(SPLIT(A1,",")) - 2,  // 倒数第二个元素        CONCATENATE(item, "和"),        IF(          index = COUNT(SPLIT(A1,",")) - 1,  // 最后一个元素          item,          CONCATENATE(item, "、")  // 其他元素        )      )    )  ) )
  • 6关注人数
  • 75浏览人数
  • 最后回答于:2025-7-15 09:44
