查看日志,显示 数据集生成错误:NullPointerException: packageName :ETLData entryInfoName :lastest_price_historical 07:27:47 table-load-pool-2-thread-16 ERROR [standard] java.lang.NullPointerException at com.fr.engine.bi.config.AbstractEntityFactory.createByDriver(AbstractEntityFactory.java:49) at com.fr.engine.bi.config.AbstractEntityFactory.create(AbstractEntityFactory.java:27) at com.fr.engine.bi.distribute.DefaultDistributorModel.createSimpleBaseEntity(DefaultDistributorModel.java:66) at com.fr.engine.bi.distribute.DefaultDistributorModel.getEntity(DefaultDistributorModel.java:50) at com.fr.engine.analysis.translator.SelectFieldCriteriaHelper.createEntity(SelectFieldCriteriaHelper.java:373) at com.fr.engine.analysis.translator.SelectFieldCriteriaHelper.create(SelectFieldCriteriaHelper.java:100) at com.fr.engine.analysis.processor.SelectFieldProcessor.getCriteria(SelectFieldProcessor.java:288) at com.fr.engine.analysis.processor.SelectFieldProcessor.realProcess(SelectFieldProcessor.java:276) at com.fr.engine.analysis.processor.AbstractOperatorProcessor.process(AbstractOperatorProcessor.java:38) at com.fr.engine.analysis.processor.OperatorProcessorManager.createETLOperators(OperatorProcessorManager.java:44) at com.fr.engine.analysis.processor.OperatorProcessorManager.processWrapper(OperatorProcessorManager.java:27) at com.fr.engine.analysis.table.AnalysisTableSavaProcedure.saveTableInDistribute(AnalysisTableSavaProcedure.java:51) at com.fr.engine.analysis.table.AnalysisTableSavaProcedure.process(AnalysisTableSavaProcedure.java:45) at com.fr.engine.distribute.local.timerjob.task.load.AnalysisLoad.load(AnalysisLoad.java:88) at com.fr.engine.distribute.local.timerjob.task.load.AbstractLoad.loadWithResult(AbstractLoad.java:51) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 07:27:47 table-load-pool-2-thread-16 ERROR [standard] catch exception java.lang.NullPointerException at com.fr.engine.bi.config.AbstractEntityFactory.createByDriver(AbstractEntityFactory.java:49) at com.fr.engine.bi.config.AbstractEntityFactory.create(AbstractEntityFactory.java:27) at com.fr.engine.bi.distribute.DefaultDistributorModel.createSimpleBaseEntity(DefaultDistributorModel.java:66) at com.fr.engine.bi.distribute.DefaultDistributorModel.getEntity(DefaultDistributorModel.java:50) at com.fr.engine.analysis.translator.SelectFieldCriteriaHelper.createEntity(SelectFieldCriteriaHelper.java:373) at com.fr.engine.analysis.translator.SelectFieldCriteriaHelper.create(SelectFieldCriteriaHelper.java:100) at com.fr.engine.analysis.processor.SelectFieldProcessor.getCriteria(SelectFieldProcessor.java:288) at com.fr.engine.analysis.processor.SelectFieldProcessor.realProcess(SelectFieldProcessor.java:276) at com.fr.engine.analysis.processor.AbstractOperatorProcessor.process(AbstractOperatorProcessor.java:38) at com.fr.engine.analysis.processor.OperatorProcessorManager.createETLOperators(OperatorProcessorManager.java:44) at com.fr.engine.analysis.processor.OperatorProcessorManager.processWrapper(OperatorProcessorManager.java:27) at com.fr.engine.analysis.table.AnalysisTableSavaProcedure.saveTableInDistribute(AnalysisTableSavaProcedure.java:51) at com.fr.engine.analysis.table.AnalysisTableSavaProcedure.process(AnalysisTableSavaProcedure.java:45) at com.fr.engine.distribute.local.timerjob.task.load.AnalysisLoad.load(AnalysisLoad.java:88) at com.fr.engine.distribute.local.timerjob.task.load.AbstractLoad.loadWithResult(AbstractLoad.java:51) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 07:27:48 TaskManager thread-20 ERROR [standard] [UpdateMessage] print error log: |
