独立部署Tomcat报错,求帮助!
L`A9OZ(QEWE)$FDFL{QFX8Y.png实在看不出来问题,启动报一大堆错误,下面是报得全部错误,大神会的帮看看
Using CATALINA_BASE:   "E:\FineReport10.0\apache-tomcat-8.5.37"
Using CATALINA_HOME:   "E:\FineReport10.0\apache-tomcat-8.5.37"
Using CATALINA_TMPDIR: "E:\FineReport10.0\apache-tomcat-8.5.37\temp"
Using JRE_HOME:        "C:\Program Files\Java\jdk1.8.0_111"
Using CLASSPATH:       "E:\FineReport10.0\apache-tomcat-8.5.37\bin\bootstrap.jar;E:\FineReport10.0\apache-tomcat-8.5.37\bin\tomcat-juli.jar"
08-Jan-2019 14:09:00.717 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Server version:        Apache Tomcat/8.5.37
08-Jan-2019 14:09:00.721 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Server built:          Dec 12 2018 12:07:02 UTC
08-Jan-2019 14:09:00.722 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Server number:         8.5.37.0
08-Jan-2019 14:09:00.722 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name:               Windows 10
08-Jan-2019 14:09:00.722 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version:            10.0
08-Jan-2019 14:09:00.722 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture:          amd64
08-Jan-2019 14:09:00.722 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home:             C:\Program Files\Java\jdk1.8.0_111\jre
08-Jan-2019 14:09:00.723 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version:           1.8.0_111-b14
08-Jan-2019 14:09:00.726 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor:            Oracle Corporation
08-Jan-2019 14:09:00.726 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE:         E:\FineReport10.0\apache-tomcat-8.5.37
08-Jan-2019 14:09:00.727 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME:         E:\FineReport10.0\apache-tomcat-8.5.37
08-Jan-2019 14:09:00.727 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=E:\FineReport10.0\apache-tomcat-8.5.37\conf\logging.properties
08-Jan-2019 14:09:00.727 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
08-Jan-2019 14:09:00.728 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
08-Jan-2019 14:09:00.728 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
08-Jan-2019 14:09:00.729 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
08-Jan-2019 14:09:00.730 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=E:\FineReport10.0\apache-tomcat-8.5.37
08-Jan-2019 14:09:00.731 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=E:\FineReport10.0\apache-tomcat-8.5.37
08-Jan-2019 14:09:00.732 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=E:\FineReport10.0\apache-tomcat-8.5.37\temp
08-Jan-2019 14:09:00.733 淇℃伅 [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded APR based Apache Tomcat Native library [1.2.19] using APR version [1.6.5].
08-Jan-2019 14:09:00.733 淇℃伅 [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
08-Jan-2019 14:09:00.734 淇℃伅 [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR/OpenSSL configuration: useAprConnector [false], useOpenSSL [true]
08-Jan-2019 14:09:00.744 淇℃伅 [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 1.1.1a  20 Nov 2018]
08-Jan-2019 14:09:00.884 淇℃伅 [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
08-Jan-2019 14:09:01.274 淇℃伅 [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
08-Jan-2019 14:09:01.287 淇℃伅 [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
08-Jan-2019 14:09:01.291 淇℃伅 [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
08-Jan-2019 14:09:01.293 淇℃伅 [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1018 ms
08-Jan-2019 14:09:01.326 淇℃伅 [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
08-Jan-2019 14:09:01.326 淇℃伅 [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.37
08-Jan-2019 14:09:01.338 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\docs]
08-Jan-2019 14:09:01.643 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\docs] has finished in [304] ms
08-Jan-2019 14:09:01.643 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\examples]
08-Jan-2019 14:09:02.053 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\examples] has finished in [410] ms
08-Jan-2019 14:09:02.053 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\host-manager]
08-Jan-2019 14:09:02.091 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\host-manager] has finished in [38] ms
08-Jan-2019 14:09:02.092 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\manager]
08-Jan-2019 14:09:02.130 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\manager] has finished in [38] ms
08-Jan-2019 14:09:02.131 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\ROOT]
08-Jan-2019 14:09:02.163 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\ROOT] has finished in [32] ms
08-Jan-2019 14:09:02.164 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [E:\FineReport10.0\apache-tomcat-8.5.37\webapps\WebReport]
[ERROR]Cannot not find com.sun.tools.attach.VirtualMachine or com.ibm.tools.attach.VirtualMachine.
[INFO]Starting fine assist...
[ERROR]Fine assist start failed.
[ERROR]null
java.lang.NullPointerException
        at com.fr.invoke.Reflect.exactMethod(Unknown Source)
        at com.fr.invoke.Reflect.call(Unknown Source)
        at com.fr.jvm.assist.FineAssist.loadNativeLibrary(Unknown Source)
        at com.fr.runtime.FineRuntime.
        at com.fr.startup.FineWebApplicationStartup.
        at com.fr.startup.FineWebApplicationInitializer.onStartup(Unknown Source)
        at com.fr.third.springframework.web.SpringServletContainerInitializer.onStartup(SpringServletContainerInitializer.java:175)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5267)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:754)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:730)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734)
        at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1140)
        at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1875)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
[INFO]Starting fine runtime...
[ERROR]com.fr.plugin.bridge.FinePluginBridge
java.lang.ClassNotFoundException: com.fr.plugin.bridge.FinePluginBridge
        at com.fr.plugin.Start.findClass(Unknown Source)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
        at com.fr.plugin.Start.loadClass(Unknown Source)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:348)
        at com.fr.runtime.FineRuntime.initEncryptedBridge(Unknown Source)
        at com.fr.runtime.FineRuntime.start(Unknown Source)
Caused by: java.lang.ClassFormatError: Incompatible magic value 50661129 in class file com/fr/plugin/bridge/FinePluginBridge
        at sun.misc.Unsafe.defineClass(Native Method)
        ... 22 more
[INFO]Fine runtime started.
[DEBUG]Module not found finebi-start-foundation
[DEBUG]Module not found finebi-start-direct
[DEBUG]Module not found finebi-start-swift
[DEBUG]Module not found finebi-decision-dependency
[DEBUG]Module not found decision-bi
[DEBUG]Module not found schedule-bi
[INFO]Module server-startup starting...
[INFO]Module server-basic starting...
[INFO]Module basic starting...
[INFO]Success to start fine analyzer: sun.instrument.InstrumentationImpl@ae8d332.
[INFO]Success to install instrumentation.
[DEBUG]transform successfully:class com.fr.base.EmailManager
[INFO]Module locale starting...
[INFO]Module locale started.Time used 3 ms.
[INFO]Module default-logger starting...
14:09:18 localhost-startStop-1 INFO [standard] Module default-logger started.Time used 92 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module class-factory starting...
14:09:18 localhost-startStop-1 INFO [standard] Module class-factory started.Time used 4 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module serialization starting...
14:09:18 localhost-startStop-1 INFO [standard] Module serialization started.Time used 4 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module workspace starting...
14:09:18 localhost-startStop-1 INFO [standard] Module workspace-register starting...
14:09:18 localhost-startStop-1 INFO [standard] Module workspace-register started.Time used 0 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module workspace started.Time used 13 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module atom starting...
14:09:18 localhost-startStop-1 INFO [standard] Module atom started.Time used 7 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module xmlable starting...
14:09:18 localhost-startStop-1 INFO [standard] Module xmlable started.Time used 0 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module basic started.Time used 1165 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module server-workspace-provider starting...
14:09:18 localhost-startStop-1 INFO [standard] Module server-workspace-provider started.Time used 42 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module core starting...
14:09:18 localhost-startStop-1 INFO [standard] Module base-res starting...
14:09:18 localhost-startStop-1 INFO [standard] Module base-res started.Time used 19 ms.
14:09:18 localhost-startStop-1 INFO [standard] Module basedb starting...
14:09:19 pool-1-thread-1 ERROR [com.fr.third.alibaba.druid.pool.DruidDataSource] testOnBorrow is true, validationQuery not set
14:09:19 pool-1-thread-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource] {dataSource-1} inited
一月 08, 2019 2:09:21 下午 com.fr.third.org.hibernate.type.descriptor.java.JavaTypeDescriptorRegistry getDescriptor
WARN: Could not find matching type descriptor for requested Java class [java.util.List]; using fallback
WARN: Could not find matching type descriptor for requested Java class [com.fr.swift.source.alloter.AllotRule]; using fallback
14:09:21 localhost-startStop-1 INFO [standard] Module basedb started.Time used 3437 ms.
14:09:21 localhost-startStop-1 INFO [standard] Module configuration starting...
14:09:21 localhost-startStop-1 INFO [standard] Module configuration started.Time used 29 ms.
14:09:21 localhost-startStop-1 INFO [standard] Module restriction starting...
14:09:21 localhost-startStop-1 INFO [standard] Module restriction started.Time used 10 ms.
14:09:21 localhost-startStop-1 INFO [standard] Module log starting...
14:09:21 localhost-startStop-1 INFO [standard] Module logger starting...
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
14:09:23 localhost-startStop-1 ERROR [standard] Lifecycle error.null
        at com.fr.plugin.db.PluginDBManager.onInit(Unknown Source)
        at com.fr.plugin.db.base.BasePluginDBManager.init(Unknown Source)
        at com.fr.plugin.db.PluginDBActivator.start(Unknown Source)
        at com.fr.module.engine.FineModule.executeStart(Unknown Source)
        at com.fr.stable.lifecycle.AbstractLifecycle.start(Unknown Source)
        at com.fr.module.engine.FineModule.start(Unknown Source)
        at com.fr.module.engine.FineModule.startChildren(Unknown Source)
        at com.fr.startup.FineWebApplicationStartup.executeStart(Unknown Source)
14:09:23 localhost-startStop-1 ERROR [standard] cannot find class
 java.lang.ClassNotFoundException: com.fr.io.repository.base.fs.FSRepositoryProfile
        at com.fr.invoke.ClassFactory.classForName(Unknown Source)
        at com.fr.stable.StableUtils.classForName(Unknown Source)
        at com.fr.config.utils.ConfigReadCacheUtils.readObjectFromCache(Unknown Source)
        at com.fr.config.utils.ConfigReadCacheUtils.readMapFromCache(Unknown Source)
        at com.fr.config.holder.impl.ObjectMapConf.doGet(Unknown Source)
        at com.fr.config.holder.Conf.get(Unknown Source)
        at com.fr.io.config.ResourceModuleConfig.getProfiles(Unknown Source)
        at com.fr.io.ResourceRepositoryActivator.installRepos(Unknown Source)
        at com.fr.io.ResourceRepositoryActivator.start(Unknown Source)
14:09:23 localhost-startStop-1 ERROR [standard] com.fr.license.selector.LicenseContext
 java.lang.ClassNotFoundException: com.fr.license.selector.LicenseContext
        at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1344)
        at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1172)
        at java.lang.Class.forName(Class.java:264)
        at com.fr.regist.FRCoreContext.invokeMethod(Unknown Source)
        at com.fr.regist.FRCoreContext.refresh(Unknown Source)
        at com.fr.license.LicenseActivator.start(Unknown Source)
        at com.fr.regist.FRCoreContext.getLicense(Unknown Source)
        at com.fr.license.function.BaseFunctionPoint.refreshCache(Unknown Source)
        at com.fr.license.function.BaseFunctionPoint.initCache(Unknown Source)
        at com.fr.license.function.VT4FR.
 java.lang.ExceptionInInitializerError
Caused by: java.lang.NullPointerException
        ... 32 more
14:09:26 localhost-startStop-1 ERROR [com.fr.third.alibaba.druid.pool.DruidDataSource] testOnBorrow is true, validationQuery not set
 一月 08, 2019 2:09:26 下午 com.fr.third.org.hibernate.type.descriptor.java.JavaTypeDescriptorRegistry getDescriptor
一月 08, 2019 2:09:27 下午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: SQL Warning Code: -1100, SQLState: 02000
WARN: no data
14:09:36 localhost-startStop-1 ERROR [com.fr.third.alibaba.druid.pool.DruidDataSource] testOnBorrow is true, validationQuery not set
 一月 08, 2019 2:09:36 下午 com.fr.third.org.hibernate.type.descriptor.java.JavaTypeDescriptorRegistry getDescriptor
14:09:41 localhost-startStop-1 ERROR [standard] Lifecycle error.com.fr.jvm.assist.FineAssist.signature()I
 java.lang.UnsatisfiedLinkError: com.fr.jvm.assist.FineAssist.signature()I
        at com.fr.jvm.assist.FineAssist.signature(Native Method)
        at com.fr.web.BaseServlet.JVwCFUtiBfXgYeh(Unknown Source)
        at com.fr.report.ReportActivator.initReportServlet(Unknown Source)
        at com.fr.report.ReportActivator.start(Unknown Source)
一月 08, 2019 2:09:42 下午 com.fr.third.springframework.web.context.ContextLoader initWebApplicationContext
严重: Context initialization failed
com.fr.third.springframework.beans.factory.BeanDefinitionStoreException: Failed to read candidate component class: URL [jar:file:/E:/FineReport10.0/apache-tomcat-8.5.37/webapps/WebReport/WEB-INF/lib/fine-decision-10.0.jar!/com/fr/web/controller/decision/api/entry/DirectoryResource.class]; nested exception is java.lang.NoClassDefFoundError: Could not initialize class com.fr.license.function.VT4FR
        at com.fr.third.springframework.context.annotation.ClassPathScanningCandidateComponentProvider.findCandidateComponents(ClassPathScanningCandidateComponentProvider.java:303)
        at com.fr.third.springframework.context.annotation.ClassPathBeanDefinitionScanner.doScan(ClassPathBeanDefinitionScanner.java:240)
        at com.fr.third.springframework.context.annotation.ClassPathBeanDefinitionScanner.scan(ClassPathBeanDefinitionScanner.java:218)
        at com.fr.third.springframework.web.context.support.AnnotationConfigWebApplicationContext.loadBeanDefinitions(AnnotationConfigWebApplicationContext.java:219)
        at com.fr.third.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:129)
        at com.fr.third.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:542)
        at com.fr.third.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:454)
        at com.fr.third.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:403)
        at com.fr.third.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:306)
        at com.fr.startup.FineWebApplicationStartup$SpringStarter.executeStart(Unknown Source)
        at com.fr.startup.FineWebApplicationInitializer$1.contextInitialized(Unknown Source)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4810)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5278)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class com.fr.license.function.VT4FR
        at sun.misc.Unsafe.ensureClassInitialized(Native Method)
        at sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(UnsafeFieldAccessorFactory.java:43)
        at sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFactory.java:142)
        at java.lang.reflect.Field.acquireFieldAccessor(Field.java:1088)
        at java.lang.reflect.Field.getFieldAccessor(Field.java:1069)
        at java.lang.reflect.Field.get(Field.java:393)
        at com.fr.third.springframework.core.type.classreading.AbstractRecursiveAnnotationVisitor.getEnumValue(AbstractRecursiveAnnotationVisitor.java:83)
        at com.fr.third.springframework.core.type.classreading.AbstractRecursiveAnnotationVisitor.visitEnum(AbstractRecursiveAnnotationVisitor.java:73)
        at com.fr.third.springframework.asm.ClassReader.readAnnotationValue(ClassReader.java:1871)
        at com.fr.third.springframework.asm.ClassReader.readAnnotationValues(ClassReader.java:1793)
        at com.fr.third.springframework.asm.ClassReader.accept(ClassReader.java:642)
        at com.fr.third.springframework.asm.ClassReader.accept(ClassReader.java:508)
        at com.fr.third.springframework.core.type.classreading.SimpleMetadataReader.
        at com.fr.third.springframework.core.type.classreading.SimpleMetadataReaderFactory.getMetadataReader(SimpleMetadataReaderFactory.java:98)
        at com.fr.third.springframework.core.type.classreading.CachingMetadataReaderFactory.getMetadataReader(CachingMetadataReaderFactory.java:102)
        at com.fr.third.springframework.context.annotation.ClassPathScanningCandidateComponentProvider.findCandidateComponents(ClassPathScanningCandidateComponentProvider.java:279)
        ... 24 more
14:09:42 localhost-startStop-1 ERROR [standard] Lifecycle error.Failed to read candidate component class: URL [jar:file:/E:/FineReport10.0/apache-tomcat-8.5.37/webapps/WebReport/WEB-INF/lib/fine-decision-10.0.jar!/com/fr/web/controller/decision/api/entry/DirectoryResource.class]; nested exception is java.lang.NoClassDefFoundError: Could not initialize class com.fr.license.function.VT4FR
        ... 24 more
一月 08, 2019 2:09:42 下午 com.fr.third.springframework.web.servlet.DispatcherServlet initServletBean
        ... 24 more
一月 08, 2019 2:09:42 下午 org.apache.catalina.core.ApplicationContext log
严重: StandardWrapper.Throwable
FineReport 15717147801 发布于 2019-1-8 14:13 (编辑于 2019-1-8 16:10)
共5回答
发布于2020-10-30 17:53(编辑于 2020-10-30 17:53)
发布于2020-10-31 11:06
10.0的登入页面是
http://localhost:8075/webroot/decision
不是
http://localhost:8075/webroot/Reportserver
luozhiweiLv5见习互助
发布于2019-1-8 16:43
http://localhost:8080/WebReport/ReportServer?op=fs
访问路径问题,试试这个路径
jskeenLv0见习互助
发布于2019-2-22 11:46
若环境变量指向的%JRE_HOME%/bin下无attach.dll文件,还需将%JAVA_HOME%/jdk/jre/bin下的attach.dll拷贝到此路径下。
试一下这个,我加了之后就好了
halugLv3见习互助
发布于2019-2-22 12:11
我觉着你这个明显时WebReport目录下缺文件。从fr项目重新拷贝一份吧!
  • 6关注人数
  • 5093浏览人数
  • 最后回答于:2020-10-31 11:06
