连接本地MySQL数据库报错
2019-01-19 18:53:34
严重:18:53:34 Druid-ConnectionPool-Create-1575635644 ERROR [com.fr.third.alibaba.druid.pool.DruidDataSource] create connection error, url: jdbc:mysql://localhost:3306/test?characterEncoding=utf8&useSSL=true, errorCode 0, state 08S01
2019-01-19 18:53:44
警告:18:53:44 pool-28-thread-1 WARN [root] 错误代码:31300012 创建数据连接失败: Communications link failure
Last packet sent to the server was 4 ms ago.
2019-01-19 18:53:44
严重:18:53:44 SwingWorker-pool-12-thread-3 ERROR [root] com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
FineReport tangshi998 发布于 2019-1-19 18:59
tangshi998Lv4初级互助
发布于2019-1-19 19:03
添加?characterEncoding=utf8即可
  • 0关注人数
  • 2219浏览人数
  • 最后回答于:2019-1-19 19:03
