Sql怎么写
select a.*,case when b.zhuanban is null then 0 else b.zhuanban end from(
    select a.*,case when b.db is null then 0 else b.db end from(
        select a.*,case when b.zb is null then 0 else b.zb end from (
            select loginname,realname from sys_user where unitid = '0203'
        )a left join (select loginname,count(1) zb from slj_info where letterstate = 8  --zhiban
            group by loginname
        )b on a.loginname = b.loginname
    )a left join (select loginname,count(1) db from slj_info where letterstate = 9  --duban
        group by loginname
)a left join (select loginname,count(1) zhuangban from slj_zhuanban
    group by loginname
最后一张slj_zhuanban怎么和前面的拼接在一起
FineReport lurui 发布于 2018-11-13 19:39
touyuan001Lv6中级互助
发布于2018-11-13 22:32
你这个问题太模糊了,太多未知的东西,都不知道你要干嘛,把提供的都提供下吧。不然没人会回答你这个问题,无从搞起
  • 572浏览人数
  • 最后回答于:2018-11-13 22:32
