Sql嵌套报错
select a.*,case when b.zhuanban is null then 0 else b.zhuanban end from(
    select a.*,case when b.db is null then 0 else b.db end from(
        select a.*,case when b.zb is null then 0 else b.zb end from (
            select loginname,realname from sys_user where unitid = '0203'
        )a left join (select loginname,count(1) zb from slj_info where letterstate = 8  --zhiban
            group by loginname
        )b on a.loginname = b.loginname
    )a left join (select loginname,count(1) db from slj_info where letterstate = 9  --duban
        group by loginname
)a left join (select loginname,count(1) zhuangban from slj_zhuanban
    group by loginname
直办督办都在info表中的状态,转办是单独一张表,怎么嵌套
lurui 发布于 2018-11-14 08:40
共5回答
影丶Lv5高级互助
发布于2018-11-14 10:11
--未经测试
select a.loginname,a.realname
     ,case when b.zb is null then 0 else b.zb end zb
     ,case when c.db is null then 0 else c.db end db
     ,case when d.zhuangban is null then 0 else d.zhuangban end zhuangban
from sys_user a
left join (
      group by loginname
)b on b.loginname = a.loginname
left join (
      group by loginname
)c on c.loginname = a.loginname
left join
      group by loginname
)d on d.loginname = a.loginname
你这是把它想得太复杂了,然后把自己套死了,没必要套那么多层。
离_度Lv3中级互助
发布于2018-11-14 09:38
没有关联条件吗?能用UNION  ALL 吗
  • lurui lurui(提问者) 三张表的loginname字段是相同的
    2018-11-14 09:52
  • 离_度 离_度 回复 lurui(提问者) 那就用你说的这个字段left join 取不到值吗?
    2018-11-14 09:55
吴浩Lv6中级互助
发布于2018-11-14 09:41
你的意思是直板,转办,和督办显示在一起是吗。(数据库是oracle吗)
  • lurui lurui(提问者) 直办督办在info表中,是letterstate 的状态 转办是另外一张表 他们关联的是loginname
    2018-11-14 09:52
  • 吴浩 吴浩 回复 lurui(提问者) select count(a.zb),count(a.db),count(b.zhuangban) from slj_info a left join slj_zhuanban b on a.loginname = b.loginname where 1=1 and a.zb is not null and a.db is not null and b.zhuanban is not null group by a.loginname,b.loginname
    2018-11-14 10:24
leeyofalLv2见习互助
发布于2018-11-14 09:59(编辑于 2018-12-26 22:08)
明显我的回答是对的,而且比被采纳的早,居然没被选上。。。
select a.loginname, a.realname,
       case when b.zb is null then 0 else b.zb end zb,
       case when c.db is null then 0 else c.db end db,
       case when d.zhuanban is null then 0 else d.zhuanban end zhuanban
  from (select loginname,realname from sys_user where unitid = '0203') a
  left join
       (select loginname, count(1) zb from slj_info where letterstate = 8  --zhiban
         group by loginname) b
  left join
       (select loginname, count(1) db from slj_info where letterstate = 8  --zhiban
         group by loginname) c
    on a.loginname = c.loginname
  left join
       (select loginname,count(1) zhuanban from slj_zhuanban
         group by loginname) d
    on a.loginname = d.loginname
圣体叶小凡Lv6高级互助
发布于2018-11-14 10:02
看看 这个时间是不是一样的,不行的话在页面做单元格过滤
  • 730浏览人数
  • 最后回答于:2018-12-26 22:08
