多个滚动轴只有一个是滚动的
如图,下面我设置了三个滚动轴,但是只有最左边的滚动播放
setTimeout(function() {
$("div[widgetname=REPORT3_C_C_C]").find("#frozen-center").css('overflow-x', 'hidden');
$("div[widgetname=REPORT3_C_C_C]").find("#frozen-center").css('overflow-y', 'hidden');
$("div[widgetname=REPORT3_C_C]").find("#frozen-north").css('overflow-x', 'hidden');
$("div[widgetname=REPORT3_C_C]").find("#frozen-north").css('overflow-y', 'hidden');
$("div[widgetname=REPORT3_C_C]").find(".reportContent").css('overflow-y', 'hidden');
$("div[widgetname=REPORT3_C_C]").find(".reportContent").css('overflow-x', 'hidden');
}, 500);
window.flag = true;
$("#frozen-center").mouseover(function() {
window.flag = false;
//鼠标悬停,滚动停止
$("#frozen-center").mouseleave(function() {
window.flag = true;
//鼠标离开,继续滚动
var old = -1;
var interval = setInterval(function() {
if (window.flag) {
currentpos = $("#frozen-center")[0].scrollTop;
if (currentpos == old) {
$("#frozen-center")[0].scrollTop = 0;
} else {
old = currentpos;
$("#frozen-center")[0].scrollTop = currentpos + 1.5;
}, 100);
//以25ms的速度每次滚动3.5PX
}, 1000)
能滚动的脚本是这样的,但是右边两个都是复制过去的,右边的表名是report_c_c_c(已经改过表名,但还是没成功),请教下是什么原因
FineReport 江一milky 发布于 2020-9-17 13:45 (编辑于 2020-9-17 13:50)
IceBall09Lv6中级互助
发布于2020-9-17 13:57
发布于2021-4-13 20:29
参考JS实现决策报表中滚屏/跑马灯效果-https://help.fanruan.com/finereport/doc-view-2393.html
注意,每个报表块初始化都写js代码,另外报表块需要设置冻结才有效,不设置冻结,跑马灯不动的
js代码
setTimeout(function({       //隐藏报表块report0的滚动条(此报表块名为report0,根据具体情况修改)    $("div[widgetname=REPORT0]").find(".frozen-north").css({        'overflow-x':'hidden',        'overflow-y':'hidden'    });    $("div[widgetname=REPORT0]").find(".frozen-center").css({        'overflow-x':'hidden',        'overflow-y':'hidden'    }); },1000); window.flag1 = true;var self1 = this;//鼠标悬停,滚动停止setTimeout(function({    $("div[widgetname=REPORT0]").find(".frozen-center").mouseover(function({        window.flag1 = false;    });     //鼠标离开,继续滚动    $("div[widgetname=REPORT0]").find(".frozen-center").mouseleave(function({        window.flag1 = true;    });     var old = -1;    var interval = setInterval(function({        if (!self1.isVisible()) {            return;        }        if (window.flag1) {            currentpos1 = $("div[widgetname=REPORT0]").find(".frozen-center")[0].scrollTop;            if (currentpos1 == old && 0!=currentpos1) {                $("div[widgetname=REPORT0]").find(".frozen-center")[0].scrollTop = 0;            } else {                old = currentpos1;                //以25ms的速度每次滚动1.5PX                $("div[widgetname=REPORT0]").find(".frozen-center")[0].scrollTop = currentpos1 + 1.5;            }        }    },    25);},1000);
  • 445浏览人数
  • 最后回答于:2021-4-13 20:29
