mysql数据库连接不上?
java.sql.SQLException: Unknown system variable 'query_cache_size' at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:963) at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3966) at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3902) at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2526) at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2673) at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2545) at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2503) at com.mysql.jdbc.StatementImpl.executeQuery(StatementImpl.java:1369) at com.mysql.jdbc.ConnectionImpl.loadServerVariables(ConnectionImpl.java:3833) at com.mysql.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:3283) at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2297) at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2083) at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:806) at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47) at sun.reflect.GeneratedConstructorAccessor131.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at com.mysql.jdbc.Util.handleNewInstance(Util.java:404) at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:410) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:328) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2153)
FineReport 用户TYRG44358 发布于 2020-9-22 19:39
发布于2020-9-22 19:52
楼主:mysql连接报错,用的mysql8.0版本吧,系统内置的驱动无法满足连接需求,参考文档下载更新驱动程序后,重启服务再连即可解决。
JDBC 连接 MySQL8.0 版本数据库-https://help.fanruan.com/finereport/doc-view-2863.html
yinewstarLv5初级互助
发布于2020-9-22 19:49
是因为系统安装的数据库版本太高,而项目中导入的jdbc 的jar包版本太低,两者不一致所导致的
  • 615浏览人数
  • 最后回答于:2020-9-22 19:52
