查询所有人两个科目的等级,显示的是下面这张表的
用户50636515 发布于 2020-9-27 16:11
圣体叶小凡Lv6高级互助
发布于2021-4-29 15:38
先行转列,然后你再 case when判断a,b,c;
select NAME ,
case when English >=90 then 'A' when English>=80 and English <90 then 'B' else 'C'  end as English,
case when English >=90 then 'A' when Math>=80 and Math <90 then 'B' else 'C'  end as Math,
case when English >=90 then 'A' when French>=80 and French <90 then 'B' else 'C'  end as French,
case when English >=90 then 'A' when Chemistry>=80 and Chemistry <90 then 'B' else 'C'  end as Chemistry
 from (
SELECT
    t1.NAME,
    MAX( CASE t1.course WHEN 'English' THEN t1.GRADE ELSE 0 END ) English,
    MAX( CASE t1.course WHEN 'Math' THEN t1.GRADE ELSE 0 END ) Math,
    MAX( CASE t1.course WHEN 'French' THEN t1.GRADE ELSE 0 END ) French,
    MAX( CASE t1.course WHEN 'Chemistry' THEN t1.GRADE ELSE 0 END ) Chemistry
FROM
    STSCORE t1
GROUP BY
    t1.NAME
) a
指间沙Lv6中级互助
发布于2020-9-27 16:22(编辑于 2020-9-27 16:23)
你把创建表sql导出来给我
sayLv6初级互助
发布于2020-9-27 16:36(编辑于 2020-9-27 16:37)
select a.studentno,a.name ,case when a.course='english' then a.flevel else ''end as english,case when a.course='french' then a.flevel else ''end as french from (select studentno,name,courses,case when grade >=90 then 'A' case when grade >=80 and grade<90then'B'else 'C'end as FLEVEL ) from 表)a
  • 580浏览人数
  • 最后回答于:2021-4-29 15:38
