求教:修改下这个JS
文本框小数测试.cpt
日志抛出错误
严重:16:00:36 http-nio-8075-exec-7 ERROR [standard] 错误代码:11201000 JS抛错
具体错误:Cannot read property 'getValue' of null
错误堆栈:TypeError: Cannot read property 'getValue' of null
    at FR.WLGP.stopCellEditing (http://localhost:8075/webroot/decision/view/report?viewlet=11111111.cpt&op=write:358:22)
    at FR.WLGP.selectTDCell (http://localhost:8075/webroot/decision/view/report?viewlet=11111111.cpt&op=write:342:487)
    at sb.eval (eval at
    at sb.
    at eval (eval at
    at sb.eval (eval at jsonDecode (http://localhost:8075/webroot/decision/view/report?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2020.11.13.20.06.57.429&jsVersion=1606357053392:533:290),
    at Object.tc (http://localhost:8075/webroot/decision/view/report?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2020.11.13.20.06.57.429&jsVersion=1606357053392:501:111)
    at sb.action (eval at jsonDecode (http://localhost:8075/webroot/decision/view/report?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2020.11.13.20.06.57.429&jsVersion=1606357053392:533:290),
    at sb.
    at sb.fireEvent (http://localhost:8075/webroot/decision/view/report?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2020.11.13.20.06.57.429&jsVersion=1606357053392:566:127)
var endrate = this.getValue();
var cell = contentPane.curLGP.getTDCell(1, 1);
contentPane.curLGP.selectTDCell(cell);
var a = this.getValue();
var location = this.options.location; //获取当前控件的位置
var cr = FR.cellStr2ColumnRow(location);
var col = cr.col; //列号
var ro = cr.row; //行号
//这里是正则表达式在js里的判断用法
if (/^\d+(\.\d{1,2})?$/.test(endrate)) {} else {
    alert("课消请输入精度为两位小数以内的正数!");
    contentPane.setCellValue(col, ro, "0.00");
原始的需求是这个文本框输入小数过后超过2位小数就弹出提示
1606809950(1).jpg 一直在加载处理中
Zero丶zero 发布于 2020-12-1 16:04 (编辑于 2020-12-1 16:10)
luojian0323Lv7资深互助
发布于2020-12-1 16:08(编辑于 2020-12-1 16:28)
代码正常
//var cell = contentPane.curLGP.getTDCell(1, 1);
//contentPane.curLGP.selectTDCell(cell);
//这里是正则表达式在js里的判断用法
不知道你那个选择单元格有何义,去掉就不报错了。
  • 558浏览人数
  • 最后回答于:2020-12-1 16:28
