打开所有报表都报这个错,这是什么问题?
java.lang.NullPointerException
	at sun.awt.FontConfiguration.getVersion(FontConfiguration.java:1264)
	at sun.awt.FontConfiguration.readFontConfigFile(FontConfiguration.java:219)
	at sun.awt.FontConfiguration.init(FontConfiguration.java:107)
	at sun.awt.X11FontManager.createFontConfiguration(X11FontManager.java:774)
	at sun.font.SunFontManager$2.run(SunFontManager.java:431)
	at java.security.AccessController.doPrivileged(Native Method)
	at sun.font.SunFontManager.(SunFontManager.java:376)
	at sun.awt.FcFontManager.(FcFontManager.java:35)
	at sun.awt.X11FontManager.(X11FontManager.java:57)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
FineReport wangfutao 发布于 2020-12-21 12:42 (编辑于 2020-12-21 13:06)
发布于2020-12-21 13:10
解决方案:linux系统没有相关font资源,需要为系统安装字体管理器;
使用了openjdk 环境,缺少FontConfiguration组件,依赖包;
操作方法:centos系统  yum install fontconfig
               debian系统 apt-get install fontconfig
导出Excel报错-https://help.fanruan.com/finebi/doc-view-578.html
  • 371浏览人数
  • 最后回答于:2020-12-21 13:10
