Lock\'TRIGGER_ACCESS\'isdesiredby这是啥意思呢大神谢谢
怎么解决呢 谢谢    [DEBUG] 2020-12-23 17:32:27,026 method:com.fr.third.org.quartz.impl.jdbcjobstore
.SimpleSemaphore.obtainLock(SimpleSemaphore.java:86)
Lock 'TRIGGER_ACCESS' is desired by: QuartzScheduler_QuartzSchedulerThread
.SimpleSemaphore.obtainLock(SimpleSemaphore.java:93)
Lock 'TRIGGER_ACCESS' is being obtained: QuartzScheduler_QuartzSchedulerThread
.SimpleSemaphore.obtainLock(SimpleSemaphore.java:110)
Lock 'TRIGGER_ACCESS' given to: QuartzScheduler_QuartzSchedulerThread
.SimpleSemaphore.releaseLock(SimpleSemaphore.java:137)
Lock 'TRIGGER_ACCESS' retuned by: QuartzScheduler_QuartzSchedulerThread
[DEBUG] 2020-12-23 17:32:27,026 method:com.fr.third.org.quartz.simpl.SimpleJobFa
ctory.newJob(SimpleJobFactory.java:50)
Producing instance of Job 'baobiao.cpt', cla
ss=com.fr.fs.schedule.job.WriteReportletJob
[DEBUG] 2020-12-23 17:32:27,026 method:com.fr.third.org.quartz.core.JobRunShell.
run(JobRunShell.java:201)
Calling execute on job baobiao.cpt
Lock 'TRIGGER_ACCESS' is desired by: QuartzScheduler_Worker-9
Lock 'TRIGGER_ACCESS' is being obtained: QuartzScheduler_Worker-9
FineReport 张宇 发布于 2020-12-24 14:38
烟尘Lv6高级互助
发布于2020-12-24 14:46
像是定时任务锁死了,把定时任务关了,重启一下服务试试
  • 张宇 张宇(提问者) 帆软决策系统里的定时任务吗 ?有上百个定时任务呢 都关了?
    2020-12-24 14:47
  • 烟尘 烟尘 回复 张宇(提问者) 重启一下服务试试
    2020-12-24 15:08
  • 张宇 张宇(提问者) 回复 烟尘 重启了 还是这样
    2020-12-24 15:11
  • 1612浏览人数
  • 最后回答于:2020-12-24 14:46
