根据不同的参数,groupby条件不一样
select data_class,year_,month_,item_type,item_type_F,area_1_channel,area_2_channel_F,sale_type_class,
       sum(销量) as 销量,sum(实际销量) as 实际销量,sum(收入) as 收入,sum(实际收入) as 实际收入,
   sum(毛利额) as 毛利额,sum(实际毛利额) as 实际毛利额
from
(select data_class,year_,month_,item_type,item_type_F,area_1_channel,area_2_channel,area_2_channel_F,sale_type_class,
       case when data_class='${数据类型1}' then qty else 0 end as 销量,
       case when data_class='${数据类型2}' then qty else 0 end as 实际销量,
   case when data_class='${数据类型1}' then rev else 0 end as 收入,
       case when data_class='${数据类型2}' then rev else 0 end as 实际收入,
       case when data_class='${数据类型1}' then gp else 0 end as 毛利额,
       case when data_class='${数据类型2}' then gp else 0 end as 实际毛利额
from
select data_class,year_,month_,item_type,item_type as item_type_F,area_1_channel,area_2_channel,area_2_channel as area_2_channel_F,sale_type_class,qty,rev,gp
from O_IFS_UNION_DUAN2DUAN
union all
select data_class,year_,month_,item_type,'CBG_OBG' as item_type_F,area_1_channel,area_2_channel,'total' as area_2_channel_F,sale_type_class,qty,rev,gp
) a
where data_class in ('${数据类型1}','${数据类型2}')
and year_='${年}'
and month_ in ('${月}' )
and 1=1 ${if(项目类别='CBG_OBG',"AND item_type_F='CBG_OBG'",
 if(len(二级渠道_国家)==0,"AND item_type_F='"+项目类别+"' and area_1_channel = '"+一级渠道_区域+"' ",
 "AND item_type_F='"+项目类别+"' and area_1_channel = '"+一级渠道_区域+"'and area_2_channel_F ='"+二级渠道_国家+"'")  )}
) A
group by data_class,year_,month_,item_type,item_type_F,area_1_channel,area_2_channel_F,sale_type_class
以上是sql,当用户选择data_class参数时,如果选择了CBG或者OBG是,group by需要对area_1_channel,area_2_channel_F这两个字段进行分组,如果选择CBG_OBG则意味着选择的是所有数据,则不需要对后面两个下级字段进行分组,请问哪位大佬有好的实现办法
Kya 发布于 2021-1-29 14:20
shirokoLv6资深互助
发布于2021-1-29 14:50
GROUP BY data_class,year_,month_,item_type,item_type_F ${IF(data_class='CBG'||data_class='OBG'," ,area_1_channel,area_2_channel_F
  • Kya Kya(提问者) group by里面少了sale_type_class字段,但是加进去,还是现实不是group by 表达式
    2021-01-29 15:00
  • shiroko shiroko 回复 Kya(提问者) 因为你字段还要再处理,如果没有group的字段是不能select的
    2021-01-29 15:02
  • Kya Kya(提问者) 实现了,谢谢
    2021-01-29 15:10
一心向明月Lv5见习互助
发布于2021-1-29 14:45
可以参考一下动态列
  • 415浏览人数
  • 最后回答于:2021-1-29 14:50
