求个mysql查询语句问题,把2个select语句合并成一个,结果集如图所示
select count(*) as '总订单',date_format(plan_start_date,'%m') as month from ppc_produce_plan group by month
select count(*) as '完成订单数量',date_format(actual_end_date,'%m') as month from ppc_produce_plan where  status=40 group by month;
FineReport 用户67195424 发布于 2021-1-29 18:00
ycswyw1123Lv6初级互助
发布于2021-1-29 18:03(编辑于 2021-1-29 18:06)
select ifnull(a.month,b.month) as month,a.总订单,b.完成订单数量 from  (select count(*) as '总订单',date_format(plan_start_date,'%m') as month from ppc_produce_plan group by month ) a,(select count(*) as '完成订单数量',date_format(actual_end_date,'%m') as month from ppc_produce_plan where  status=40 group by month) b where  a.month=b.month
  • 289浏览人数
  • 最后回答于:2021-1-29 18:06
