启动报错
D:\jdk\bin\java.exe -agentlib:jdwp=transport=dt_socket,address=127.0.0.1:61603,suspend=y,server=n -javaagent:C:\Users\DELL\AppData\Local\JetBrains\IntelliJIdea2021.1\captureAgent\debugger-agent.jar -Dfile.encoding=UTF-8 -classpath "D:\jdk\jre\lib\charsets.jar;D:\jdk\jre\lib\deploy.jar;D:\jdk\jre\lib\ext\access-bridge-64.jar;D:\jdk\jre\lib\ext\cldrdata.jar;D:\jdk\jre\lib\ext\dnsns.jar;D:\jdk\jre\lib\ext\jaccess.jar;D:\jdk\jre\lib\ext\jfxrt.jar;D:\jdk\jre\lib\ext\localedata.jar;D:\jdk\jre\lib\ext\nashorn.jar;D:\jdk\jre\lib\ext\sunec.jar;D:\jdk\jre\lib\ext\sunjce_provider.jar;D:\jdk\jre\lib\ext\sunmscapi.jar;D:\jdk\jre\lib\ext\sunpkcs11.jar;D:\jdk\jre\lib\ext\zipfs.jar;D:\jdk\jre\lib\javaws.jar;D:\jdk\jre\lib\jce.jar;D:\jdk\jre\lib\jfr.jar;D:\jdk\jre\lib\jfxswt.jar;D:\jdk\jre\lib\jsse.jar;D:\jdk\jre\lib\management-agent.jar;D:\jdk\jre\lib\plugin.jar;D:\jdk\jre\lib\resources.jar;D:\jdk\jre\lib\rt.jar;H:\application-program\target\classes;H:\javaweb\m2\com\fr\fine-core-10.0.jar;H:\javaweb\m2\com\fr\fine-datasource-10.0.jar;H:\javaweb\m2\com\fr\fine-decision-10.0.jar;H:\javaweb\m2\com\fr\fine-decision-report-10.0.jar;H:\javaweb\m2\com\fr\fine-report-engine-10.0.jar;H:\javaweb\m2\com\fr\fine-schedule-10.0.jar;H:\javaweb\m2\com\fr\fine-schedule-report-10.0.jar;H:\javaweb\m2\com\fr\fine-swift-log-adaptor-10.0.jar;H:\javaweb\m2\com\fr\fine-third-10.0.jar;H:\javaweb\m2\com\fr\fine-webui-10.0.jar;D:\ireport\FineReport_10.0\webapps\webroot\WEB-INF\lib\fine-accumulator-10.0.jar;H:\tools.jar;H:\javaweb\m2\org\java-websocket\Java-WebSocket\1.3.0\Java-WebSocket-1.3.0.jar;H:\javaweb\m2\org\springframework\spring-tx\5.2.11.RELEASE\spring-tx-5.2.11.RELEASE.jar;H:\javaweb\m2\org\springframework\spring-beans\5.2.11.RELEASE\spring-beans-5.2.11.RELEASE.jar;H:\javaweb\m2\org\springframework\spring-core\5.2.11.RELEASE\spring-core-5.2.11.RELEASE.jar;H:\javaweb\m2\org\springframework\spring-jcl\5.2.11.RELEASE\spring-jcl-5.2.11.RELEASE.jar;H:\javaweb\m2\org\junit\jupiter\junit-jupiter\5.8.0-M1\junit-jupiter-5.8.0-M1.jar;H:\javaweb\m2\org\junit\jupiter\junit-jupiter-api\5.8.0-M1\junit-jupiter-api-5.8.0-M1.jar;H:\javaweb\m2\org\apiguardian\apiguardian-api\1.1.1\apiguardian-api-1.1.1.jar;H:\javaweb\m2\org\opentest4j\opentest4j\1.2.0\opentest4j-1.2.0.jar;H:\javaweb\m2\org\junit\platform\junit-platform-commons\1.8.0-M1\junit-platform-commons-1.8.0-M1.jar;H:\javaweb\m2\org\junit\jupiter\junit-jupiter-params\5.8.0-M1\junit-jupiter-params-5.8.0-M1.jar;H:\javaweb\m2\org\junit\jupiter\junit-jupiter-engine\5.8.0-M1\junit-jupiter-engine-5.8.0-M1.jar;H:\javaweb\m2\org\junit\platform\junit-platform-engine\1.8.0-M1\junit-platform-engine-1.8.0-M1.jar;H:\javaweb\m2\org\jetbrains\kotlin\kotlin-stdlib-jdk8\1.4.20\kotlin-stdlib-jdk8-1.4.20.jar;H:\javaweb\m2\org\jetbrains\kotlin\kotlin-stdlib\1.4.20\kotlin-stdlib-1.4.20.jar;H:\javaweb\m2\org\jetbrains\kotlin\kotlin-stdlib-common\1.4.20\kotlin-stdlib-common-1.4.20.jar;H:\javaweb\m2\org\jetbrains\annotations\13.0\annotations-13.0.jar;H:\javaweb\m2\org\jetbrains\kotlin\kotlin-stdlib-jdk7\1.4.20\kotlin-stdlib-jdk7-1.4.20.jar;H:\javaweb\m2\org\projectlombok\lombok\1.18.2\lombok-1.18.2.jar;H:\javaweb\m2\org\apache\tomcat\embed\tomcat-embed-websocket\9.0.39\tomcat-embed-websocket-9.0.39.jar;H:\javaweb\m2\org\apache\tomcat\embed\tomcat-embed-core\9.0.39\tomcat-embed-core-9.0.39.jar;H:\javaweb\m2\org\apache\tomcat\tomcat-annotations-api\9.0.39\tomcat-annotations-api-9.0.39.jar;H:\javaweb\m2\org\springframework\spring-context\5.3.2\spring-context-5.3.2.jar;H:\javaweb\m2\org\springframework\spring-aop\5.3.2\spring-aop-5.3.2.jar;H:\javaweb\m2\org\springframework\spring-expression\5.3.2\spring-expression-5.3.2.jar;H:\javaweb\m2\repository\com\alibaba\fastjson\1.2.75\fastjson-1.2.75.jar;D:\idea\IntelliJ IDEA 2021.1\lib\idea_rt.jar" com.lzh.PrintDemoll.JavaPrint
Connected to the target VM, address: '127.0.0.1:61603', transport: 'socket'
[INFO]Starting fine assist...
[INFO]Temp file path :C:\Users\DELL\AppData\Local\Temp
[DEBUG]failed to run any action
[INFO]Fine assist start successfully.
[INFO]Starting fine runtime...
[DEBUG]Privacy lib's Classloader is sun.misc.Launcher$AppClassLoader@18b4aac2
[DEBUG]C:\Users\DELL\AppData\Local\Temp\FinePrivacy_x86_648637360205307207476.dll loaded successfully
[INFO]Fine runtime started.
[DEBUG]Fire event AfterSwitch ,listeners : [].
[INFO]Module VirtualActivator starting...
[INFO]Module BaseDBActivator starting...
log4j:WARN No appenders could be found for logger (com.fr.third.org.jboss.logging).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN See http://logging.apache.org/log4j/1.2/faq.html#noconfig for more info.
[INFO]Module BaseDBActivator started.Time used 1723 ms.
[INFO]Module ConfigurationActivator starting...
[DEBUG]Fire event com.fr.event.BaseEvent@6cce16f4 ,listeners : [].
[DEBUG]Fire event INSTANCE ,listeners : [].
[INFO]cache invalidate com.fr.security.SecurityConfig
[DEBUG]Fire event RPC_NOTIFY ,listeners : [].
[DEBUG]Fire event com.fr.event.BaseEvent@1fc0053e ,listeners : [].
[DEBUG]Fire event AFTER_DONE ,listeners : [].
[INFO]Module ConfigurationActivator started.Time used 287 ms.
[INFO]Module StateServiceActivator starting...
[INFO][StateService] Register memory component type:standalone.
[INFO][StateService] Register memory component type:redis.
[INFO][StateService] Register memory component type:redis_cluster.
[DEBUG]Fire event com.fr.event.BaseEvent@42257bdd ,listeners : [].
[INFO][StateService] state service refresh success
[INFO][StateService] StateHubManager reset
[INFO][StateService] FineCollectionClient before changing env.
[INFO][StateService] FineCollectionClient start update collection objects.
[INFO][StateService] FineCollectionClient finish update collection objects, spend 3 ms
[INFO][StateService] FineCollectionClient after changing env.
[INFO]cache invalidate com.fr.store.StateServerPluginConfig
[DEBUG]Fire event RPC_NOTIFY ,listeners : [com.fr.store.StateServiceActivator$2@59fc684e, com.fr.store.StateServiceActivator$4@5ae81e1].
[INFO]cache invalidate com.fr.cluster.engine.base.FineClusterConfig
[INFO]Module StateServiceActivator started.Time used 249 ms.
[INFO]Module ReportBaseActivator starting...
[ERROR]Module com.fr.store.StateServiceActivator start exception, detail: [Cluster] Fine module health clinic is null.
java.lang.NullPointerException: [Cluster] Fine module health clinic is null.
at com.fr.health.factory.FineModuleHealthFactory.getClinic(Unknown Source)
at com.fr.store.StateServiceActivator.registerStateServiceHealthDetector(Unknown Source)
at com.fr.store.StateServiceActivator.start(Unknown Source)
at com.fr.module.engine.strategy.ParentFirstStrategy.doStart(Unknown Source)
at com.fr.module.engine.strategy.AbstractInvokeSubStrategy.start(Unknown Source)
at com.fr.module.engine.FineModule$FineModuleRunner.executeStart(Unknown Source)
at com.fr.stable.lifecycle.AbstractLifecycle.start(Unknown Source)
at com.fr.module.engine.FineModule$FineModuleRunner.start(Unknown Source)
at com.fr.module.engine.FineModule.start(Unknown Source)
at com.fr.module.engine.strategy.AbstractInvokeSubStrategy.startSub(Unknown Source)
at com.lzh.PrintDemoll.JavaPrint.main(JavaPrint.java:46)
[DEBUG]Fire event com.fr.event.BaseEvent@3a71c100 ,listeners : [].
[DEBUG]CloudCenter is connected to Fanruan Service
[DEBUG][Static Resource]Read data from path /report_build.txt and cache.
[INFO]Module com.fr.chart.module.ChartModule is started.
[INFO]Module com.fr.form.module.FormModule is started.
[INFO]Module com.fr.page.module.PageModule is started.
[INFO]Module com.fr.view.module.ViewModule is started.
[INFO]Module com.fr.write.module.WriteModule is started.
[INFO]Module com.fr.report.enhancement.engine.write.module.WriteEnhanceModule is started.
[INFO]Module com.fr.report.module.EngineModule is started.
[INFO]Module ReportBaseActivator started.Time used 496 ms.
[INFO]Module RestrictionActivator starting...
[INFO]Module RestrictionActivator started.Time used 14 ms.
[INFO]Module ReportActivator starting...
[INFO]Module ReportActivator started.Time used 125 ms.
[INFO]Module VirtualActivator started.Time used 2897 ms.
[DEBUG]Fire event AFTER_START ,listeners : [].
[INFO]Module virtual-root stop...
[INFO]Module com.fr.report.ReportActivator stop...
[INFO]Module com.fr.report.ReportActivator stopped.Time used 6 ms
[INFO]Module com.fr.report.RestrictionActivator stop...
[INFO]Module com.fr.report.RestrictionActivator stopped.Time used 0 ms
[INFO]Module com.fr.report.module.ReportBaseActivator stop...
[INFO]Module com.fr.report.module.ReportBaseActivator stopped.Time used 0 ms
[INFO]Module com.fr.store.StateServiceActivator stop...
[INFO]Module com.fr.store.StateServiceActivator stopped.Time used 3 ms
[INFO]Module com.fr.config.activator.ConfigurationActivator stop...
[INFO]Module com.fr.config.activator.ConfigurationActivator stopped.Time used 0 ms
[INFO]Module com.fr.config.activator.BaseDBActivator stop...
com.fr.exception.TemplateFileNotFoundException: Fine-Engine_Report_NS_Exception_No_Template
at com.fr.io.TemplateWorkBookIO.readTemplateWorkBook(Unknown Source)
at com.lzh.PrintDemoll.JavaPrint.main(JavaPrint.java:48)
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
[INFO]Module com.fr.config.activator.BaseDBActivator stopped.Time used 159 ms
[INFO]Module virtual-root stopped.Time used 171 ms
[INFO]Load cloud config spend time 1260 ms
Disconnected from the target VM, address: '127.0.0.1:61603', transport: 'socket'
Process finished with exit code 0
用户5Y4FE9179834 发布于 2021-5-15 11:32
悬赏:0 F币 + 添加悬赏
luojian0323Lv7资深互助
发布于2021-5-15 11:51
没有什么严重报错啊
  • 434浏览人数
  • 最后回答于:2021-5-15 11:51
