如果下拉框值为3.,字段1=3,如果下拉框值为0,字段1<3
下拉框值为0,字段1可以等于0,1,2
FineReport 用户C5148946 发布于 2021-5-18 14:21 (编辑于 2021-5-18 15:27)
ekDanLv6初级互助
发布于2021-5-18 14:24(编辑于 2021-5-18 14:28)
你想表达啥,问题是啥
WHERE 1 = 1
${if(下拉框 == 3,"AND 1 = 3","")}
${if(下拉框 == 0,"AND 1 != 3","")}
where后写case when也行
发布于2021-5-18 14:32
SELECT * FROM TABLE WHERE 1=1 AND ${IF(下拉=3,"字段1=3",IF(下拉=0,"字段1<>3","1<>1"))}----下拉不为3或0时查不出数据
  • 394浏览人数
  • 最后回答于:2021-5-18 15:27
