报表报错能看看咋回事呢谢谢大神
baocuo.txt
[DEBUG] 2021-06-18 08:30:00,001 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.obtainLock(SimpleSemaphore.java:93)Lock 'TRIGGER_ACCESS' is being obtained: QuartzScheduler_QuartzSchedulerThread[DEBUG] 2021-06-18 08:30:00,002 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.obtainLock(SimpleSemaphore.java:110)Lock 'TRIGGER_ACCESS' given to: QuartzScheduler_QuartzSchedulerThread[DEBUG] 2021-06-18 08:30:00,004 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.releaseLock(SimpleSemaphore.java:137)Lock 'TRIGGER_ACCESS' retuned by: QuartzScheduler_QuartzSchedulerThread[DEBUG] 2021-06-18 08:30:00,007 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.obtainLock(SimpleSemaphore.java:86)Lock 'TRIGGER_ACCESS' is desired by: QuartzScheduler_QuartzSchedulerThread[DEBUG] 2021-06-18 08:30:00,007 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.obtainLock(SimpleSemaphore.java:93)Lock 'TRIGGER_ACCESS' is being obtained: QuartzScheduler_QuartzSchedulerThread[DEBUG] 2021-06-18 08:30:00,008 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.obtainLock(SimpleSemaphore.java:110)Lock 'TRIGGER_ACCESS' given to: QuartzScheduler_QuartzSchedulerThread[DEBUG] 2021-06-18 08:30:00,009 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.releaseLock(SimpleSemaphore.java:137)Lock 'TRIGGER_ACCESS' retuned by: QuartzScheduler_QuartzSchedulerThread[DEBUG] 2021-06-18 08:30:00,010 method:com.fr.third.org.quartz.simpl.SimpleJobFactory.newJob(SimpleJobFactory.java:50)Producing instance of Job 'DDZX/yetikucun1.cpt.报表五', class=com.fr.fs.schedule.job.WriteReportletJob[DEBUG] 2021-06-18 08:30:00,011 method:com.fr.third.org.quartz.core.JobRunShell.run(JobRunShell.java:201)Calling execute on job DDZX/yetikucun1.cpt.报表六[DEBUG] 2021-06-18 08:30:00,543 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.obtainLock(SimpleSemaphore.java:86)Lock 'TRIGGER_ACCESS' is desired by: QuartzScheduler_Worker-1[DEBUG] 2021-06-18 08:30:00,544 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.obtainLock(SimpleSemaphore.java:93)Lock 'TRIGGER_ACCESS' is being obtained: QuartzScheduler_Worker-1[DEBUG] 2021-06-18 08:30:00,544 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.obtainLock(SimpleSemaphore.java:110)Lock 'TRIGGER_ACCESS' given to: QuartzScheduler_Worker-1[DEBUG] 2021-06-18 08:30:00,545 method:com.fr.third.org.quartz.impl.jdbcjobstore.SimpleSemaphore.releaseLock(SimpleSemaphore.java:137)Lock 'TRIGGER_ACCESS' retuned by: QuartzScheduler_Worker-1
FineReport 张宇 发布于 2021-6-18 09:42 (编辑于 2021-6-18 09:44)
发布于2021-12-21 17:37
——文件名什么情况?其次排查下是否存在权限问题-命令行锁异常;
  • 334浏览人数
  • 最后回答于:2021-12-21 17:37
