数据集出错了,搞不懂原因
select post_date,city_code,city_desc,tuandui,tdmc,gasstation_code,gasstation_desc, sum sum_gun as '按年提枪次数',  sum_gun as '当日提枪次数'
from app_nonoil.kl_labordata
where post_date<='${tjdate}' and year('${tjdate}')=substr(post_date,1,4)
 group by post_date,city_desc
FineReport 用户x076327 发布于 2021-7-1 11:28
发布于2021-7-1 11:31(编辑于 2021-7-1 11:32)
sum()函数,需要()把字段括起来啊
然后没有sum字段,都要在group by下面出现
select post_date,city_code,city_desc,tuandui,tdmc,gasstation_code,gasstation_desc, sum(sum_gun) as '按年提枪次数',  sum_gun as '当日提枪次数'
 group by post_date,city_code,city_desc,tuandui,tdmc,gasstation_code,gasstation_desc,sum_gun
廿三Lv6中级互助
发布于2021-7-1 11:31
 sum sum_gun as '按年提枪次数'  应该是 sum(sum_gun ) as '按年提枪次数' 吧
SrafyLv5见习互助
sum()
liu.yangLv2初级互助
发布于2021-7-1 11:39
如果你一个查询中 又想有 当日的数据 又想有当年的数据的话 就需要用开窗函数了 而不是简单的sum
select post_date,city_code,city_desc,tuandui,tdmc,gasstation_code,gasstation_desc, sum(sum_gun)over(parition by city_code) as '按年提枪次数', sum_gun as '当日提枪次数' from app_nonoil.kl_labordatawhere post_date<='${tjdate}' and year('${tjdate}')=substr(post_date,1,4)
  • 686浏览人数
  • 最后回答于:2021-7-1 11:39
