SELECT ifnull(sys_com.org_name,'未填写责任单位') as 单位, vehicle_type_name as 车型, SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')='${format(years,"yyyy-MM")}' then vr.total_reshipment end ) AS '本月运输量', SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')='${format(YEARDELTA(years,-1),'yyyy-MM')}' then vr.total_reshipment end ) AS '同期运输量', SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')<='${format(years,"yyyy-MM")}' and year(vr.reshipment_date)='${year(years)}' then vr.total_reshipment end ) AS '本年累计运输量', SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')='${format(years,"yyyy-MM")}' then vr.run_mile end ) AS '本月行驶里程', SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')='${format(YEARDELTA(years,-1),'yyyy-MM')}' then vr.run_mile end ) AS '同期行驶里程', SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')<='${format(years,"yyyy-MM")}' and year(vr.reshipment_date)='${year(years)}' then vr.run_mile end ) AS '本年行驶里程', SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')='${format(years,"yyyy-MM")}' then vr.turnover end ) AS '本月周转量', SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')='${format(YEARDELTA(years,-1),'yyyy-MM')}' then vr.turnover end ) AS '同期周转量', SUM(case when DATE_FORMAT(vr.reshipment_date, '%Y-%m')<='${format(years,"yyyy-MM")}' and year(vr.reshipment_date)='${year(years)}' then vr.turnover end ) AS '本年周转量' FROM vehicle_material_reshipment vr LEFT JOIN sys_company sys_com ON vr.org_id = sys_com.org_id left join (SELECT vehicle_id,vehicle_license,vehicle_type_name FROM vehicle_info a left join vehicle_type b on a.vehicle_type_code=b.vehicle_type_code) b ON vr.vehicle_id=b.vehicle_id where vr.deleted !=1 AND 1=1 ${IF(len(org_name)=0,'',"AND sys_com.org_name in ('"+org_name+"')")} GROUP BY sys_com.org_name,vehicle_type_name order by org_name desc,vehicle_type_name 就比如说我要查询7月份的数据 就是从6月29日---7月28日 |
最佳回答 |
