前两列数据怎么合并(Oracle)
yzm189640 发布于 2021-9-16 14:10 (编辑于 2021-9-16 14:10)
15922204585Lv6高级互助
发布于2021-9-16 14:10(编辑于 2021-9-16 14:31)
select nvl(name,name1) as name,sum(num1) as num1,sum(num2) as num2 from
select NULL as name,'李四' as name1,null as num1,20 as num2 from dual
union all
select NULL,'李五',null as num1,30 as num2 from dual
union all
select '李四',null,60 as num1,null as num2 from dual
union all
select '李五',null,30 as num1,null as num2 from dual
union all
select '张三','张三',10 as num1,10 as num2 from dual
GROUP BY nvl(name,name1)
发布于2021-9-16 14:15
数据库拼接语句
下面列举三大主流数据库的处理方式
1)Oracle 的拼接与 SQLite 的一致
SELECT user||'-'||name as username,password,position,area FROM user
2)SQL Server 使用+号进行拼接
SELECT user+'-'+name as username,password,position,area FROM user
3)MySQL 使用 concat 函数进行拼接
SELECT concat(user,'-',name) as username,password,position,area FROM user
wengleiLv4初级互助
发布于2021-9-16 14:40
select if(name is null ,name(1),name) name
    ,english
    ,french
from  table
这样的吗?
  • 466浏览人数
  • 最后回答于:2021-9-16 14:40
