jetty作为服务器,数据数据库未启动,则报表服务启动失败,如何处理?
使用jetty作为服务器,数据库为Oracle,window平台,电脑重启后,报表服务是设置了自动启动的,但启动失败了,原因是连接Oracle数据库失败。使用Tomcat就不会出现这情况,请问下使用jetty如何解决这个问题?
jetty日志如下:
2021-09-11 16:34:13 Apache Commons Daemon procrun stderr initialized.
2021-09-11 16:36:26.661:INFO::main: Logging initialized @113231ms to org.eclipse.jetty.util.log.StdErrLog
2021-09-11 16:36:48.282:WARN:oejs.HomeBaseWarning:main: This instance of Jetty is not running from a separate {jetty.base} directory, this is not recommended.  See documentation at https://www.eclipse.org/jetty/documentation/current/startup.html
2021-09-11 16:36:50.731:INFO:oejs.Server:main: jetty-9.4.35.v20201120; built: 2020-11-20T21:17:03.964Z; git: bdc54f03a5e0a7e280fab27f55c3c75ee8da89fb; jvm 1.8.0_91-b15
2021-09-11 16:36:52.229:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:///D:/jetty/webapps/] at interval 1
2021-09-11 16:38:59.697:INFO:oeja.AnnotationConfiguration:main: Scanning elapsed time=110399ms
2021-09-11 16:38:59.697:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@80503{/WebReport/ReportServer,file:///D:/WebReport/ReportServer/,UNAVAILABLE}{D:/WebReport/ReportServer}
java.lang.Exception: Timeout scanning annotations
at org.eclipse.jetty.annotations.AnnotationConfiguration.scanForAnnotations(AnnotationConfiguration.java:491)
at org.eclipse.jetty.annotations.AnnotationConfiguration.configure(AnnotationConfiguration.java:346)
at org.eclipse.jetty.webapp.WebAppContext.configure(WebAppContext.java:498)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1417)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:911)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:288)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:524)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:73)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:46)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:188)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:517)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:157)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:173)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:447)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:66)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:784)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:753)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:641)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:540)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:146)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:605)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:252)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
at org.eclipse.jetty.server.Server.start(Server.java:423)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:97)
at org.eclipse.jetty.server.Server.doStart(Server.java:387)
at org.eclipse.jetty.xml.XmlConfiguration.lambda$main$2(XmlConfiguration.java:1908)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1857)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:218)
at org.eclipse.jetty.start.Main.start(Main.java:491)
at org.eclipse.jetty.start.Main.main(Main.java:77)
2021-09-11 16:39:02.505:INFO:oejs.AbstractConnector:main: Started ServerConnector@2d2e5f00{HTTP/1.1, (http/1.1)}{0.0.0.0:8076}
2021-09-11 16:39:02.505:INFO:oejs.Server:main: Started @269065ms
2021-09-11 17:37:20.355:INFO:oejs.AbstractConnector:ShutdownMonitor: Stopped ServerConnector@2d2e5f00{HTTP/1.1, (http/1.1)}{0.0.0.0:8076}
2021-09-11 17:37:20.363:INFO:oejsh.ContextHandler:ShutdownMonitor: Stopped o.e.j.w.WebAppContext@80503{/WebReport/ReportServer,null,STOPPED}{D:/WebReport/ReportServer}
FineReport 周光 发布于 2021-9-22 14:25
发布于2021-9-22 14:32
你把报表服务设置成延时启动,
  • Z4u3z1 Z4u3z1 回复 周光(提问者) 对。windows的任务计划
    2021-09-23 08:57
  • 305浏览人数
  • 最后回答于:2021-9-22 14:32
