【有悬赏的问题】BI连接SQLSERVER2005数据库出现以下报错。
telnet 测试了数据库和端口是通的,用户名和密码验证也是正确的,SQL SERVER 2005的驱动sqljdbc42.jar也在FineBI5.1\webapps\webroot\WEB-INF\lib文件夹内,数据库名称也是正确的,按照文档把C:\Program Files\Java\jre1.8.0_221\lib\security中的3DES_EDE_CBC也删除了,也重启BI和电脑了,但是依然连不上。请大侠帮助。提出具体的解决方案,不要那种BI文档链接。以下是报错信息:
om.microsoft.sqlserver.jdbc.SQLServerException: 驱动程序无法通过使用安全套接字层(SSL)加密与 SQL Server 建立安全连接。错误:“SQL Server 未返回响应。连接已关闭。 ClientConnectionId:cf933005-0a9a-422d-8626-875d6d28fa27”。 at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:2400) at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1762) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1977) at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:1628) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:1459) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:773) at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1168) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2165) Caused by: java.io.IOException: SQL Server 未返回响应。连接已关闭。 ClientConnectionId:cf933005-0a9a-422d-8626-875d6d28fa27 at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.ensureSSLPayload(IOBuffer.java:711) at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.readInternal(IOBuffer.java:768) at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.read(IOBuffer.java:760) at com.microsoft.sqlserver.jdbc.TDSChannel$ProxyInputStream.readInternal(IOBuffer.java:955) at com.microsoft.sqlserver.jdbc.TDSChannel$ProxyInputStream.read(IOBuffer.java:943) at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) at sun.security.ssl.InputRecord.read(InputRecord.java:503) at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:975) at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367) at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395) at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379) at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1688) ... 8 more
FineBI 用户A8938353 发布于 2021-9-24 09:42 (编辑于 2021-9-24 09:44)
悬赏:9 F币 + 添加悬赏
发布于2021-9-24 10:09
——远程解决;
  • 513浏览人数
  • 最后回答于:2021-9-24 10:09
