不同的查询条件执行不同的SQL,控件复选框如何传参呢?
我想将and a.PRODUCT_ID ='T1Y10A0104PA00'    做成复选框,控件名为料号,不知道如何传参,我写的: ${if(len(料号)==0,'',"AND  a.PRODUCT_ID in ('"+料号+"')")}      结果报配置错误。请指教。下面判断的两段SQL中都有 and a.PRODUCT_ID ='T1Y10A0104PA00' 哦
SQL如下:
${if(OR ( 站点 != "17600" ,  站点 != "16600",  站点 != "19100")," select a.GE_TIME,a.PRODUCT_ID,a.EQUIPMENT_ID,a.LOT_ID,a.GLASS_ID,c.PROCESSOPERATIONNAME,c.MACHINENAME,c.CHAMBERNAME,b.PARA_NAME ietm,
                    AVG(b.VALUE) AS avgl,
                    MAX(b.VALUE) AS maxl,
                    MIN(b.VALUE) AS minl,
                    max(decode(b.SITE, 1,b.value, 0)) as S01,
                    max(decode(b.SITE, 2,b.value, 0)) as S02,
                    max(decode(b.SITE, 3,b.value, 0)) as S03,
                    max(decode(b.SITE, 4,b.value, 0)) as S04,
                    max(decode(b.SITE, 5,b.value, 0)) as S05,
                    max(decode(b.SITE, 6,b.value, 0)) as S06,
                    max(decode(b.SITE, 7,b.value, 0)) as S07,
                    max(decode(b.SITE, 8,b.value, 0)) as S08,
                    max(decode(b.SITE, 9,b.value, 0)) as S09,
                    max(decode(b.SITE, 10,b.value, 0)) as S10,
                    max(decode(b.SITE, 11,b.value, 0)) as S11,
                    max(decode(b.SITE, 12,b.value, 0)) as S12,
                    max(decode(b.SITE, 13,b.value, 0)) as S13,
                    max(decode(b.SITE, 14,b.value, 0)) as S14,
                    max(decode(b.SITE, 15,b.value, 0)) as S15,
                    max(decode(b.SITE, 16,b.value, 0)) as S16,
                    max(decode(b.SITE, 17,b.value, 0)) as S17,
                    max(decode(b.SITE, 18,b.value, 0)) as S18,
                    max(decode(b.SITE, 19,b.value, 0)) as S19,
                    max(decode(b.SITE, 20,b.value, 0)) as S20,
                    max(decode(b.SITE, 21,b.value, 0)) as S21,
                    max(decode(b.SITE, 22,b.value, 0)) as S22,
                    max(decode(b.SITE, 23,b.value, 0)) as S23,
                    max(decode(b.SITE, 24,b.value, 0)) as S24,
                    max(decode(b.SITE, 25,b.value, 0)) as S25
                    from P1DMSADM.teg_glass a,P1DMSADM.teg_site_info b ,P1DMSADM.ept_mmdchamberhistory c
                    where
                    a.PRODUCT_ID=c.PRODUCTSPECNAME
                    and a.GLASS_SEQ=b.GLASS_SEQ
                    and a.GLASS_ID=c.GLASSNAME
                    and a.LOT_ID=c.LOTNAME
                    and a.STEP_ID='19700'
                    and c.FACTORYNAME='A1'
                    and c.PROCESSOPERATIONNAME='12100'
                    and c.MACHINENAME='A1CVD100'
                    --and c.CHAMBERNAME='" + chamber + "'
                    and b.PARA_NAME in ('R2_SD_ITO')
                    --and a.GS_TIME between '20210913083000' and '20210913203000'
                    and a.GS_TIME between to_char(to_date('" + 开始时间 + "','YYYY-MM-DD'),'YYYYMMDD')||'083000' and to_char(to_date('" + 结束时间 + "','YYYY-MM-DD')+1,'YYYYMMDD')||'083000'
                    group by a.GE_TIME,a.PRODUCT_ID,a.EQUIPMENT_ID,a.LOT_ID,a.GLASS_ID,c.PROCESSOPERATIONNAME,c.MACHINENAME,c.CHAMBERNAME,b.PARA_NAME
                    order by a.GLASS_ID,c.MACHINENAME,c.CHAMBERNAME,c.PROCESSOPERATIONNAME,b.PARA_NAME     ","select a.GE_TIME,a.PRODUCT_ID,a.EQUIPMENT_ID,a.LOT_ID,a.GLASS_ID,c.OLDPROCESSOPERATIONNAME,c.MACHINENAME,c.MATERIALLOCATIONNAME,b.PARA_NAME ietm,
                      from P1DMSADM.teg_glass a,P1DMSADM.teg_site_info b ,P1DMSADM.mes_producthistory c
                      where
                         and a.GLASS_ID=c.PRODUCTNAME
                         and c.OLDPROCESSOPERATIONNAME='12100'
                   --and c.MATERIALLOCATIONNAME='" + chamber + "'
                       AND c.EVENTNAME='TrackOut'
                     and a.GS_TIME BETWEEN to_char(SUBSTR(GS_TIME,1,8)||'08300000',YYYY/MM/DD)  AND to_char(SUBSTR(GS_TIME,1,8)||'20300000',YYYY-MM-DD)
                    group by a.GE_TIME,a.PRODUCT_ID,a.EQUIPMENT_ID,a.LOT_ID,a.GLASS_ID,c.OLDPROCESSOPERATIONNAME,c.MACHINENAME,c.MATERIALLOCATIONNAME,b.PARA_NAME
                    order by a.GLASS_ID,c.MACHINENAME,c.MATERIALLOCATIONNAME,c.OLDPROCESSOPERATIONNAME,b.PARA_NAME  ")}
FineReport 用户G8480957 发布于 2021-9-27 14:43 (编辑于 2021-9-27 19:56)
free_zzLv6中级互助
发布于2021-9-27 14:52
都义JLv5见习互助
发布于2021-9-27 16:26
${if(len(料号)==0,"","AND  a.PRODUCT_ID in ('"+料号+"')")}
接双引号
还有复选框组件返回值类型字符串分隔符修改为','
StudyYLLv6初级互助
发布于2021-9-27 16:41
应该是参数嵌套的问题吧。
                    where
--and a.PRODUCT_ID ='T1Y10A0104PA00'
                      where
  • 用户G8480957 用户G8480957(提问者) 参数嵌套问题怎么传参?
    2021-09-27 19:51
  • StudyYL StudyYL 回复 用户G8480957(提问者) https://help.fanruan.com/finereport/doc-view-158.html#7 and a.PRODUCT_ID =\'T1Y10A0104PA00\'你这句怎么写的?
    2021-09-28 08:05
  • 400浏览人数
  • 最后回答于:2021-9-27 19:56
